Winter washing question
The problem with any washing in sub-freezing temperatures are all the problems we have with frozen locks, door seals and e-brakes. If you must, try to leave the car in full, bright sunshine on a day with little or no wind after washing.
When it's below freezing, I take two buckets of soapy water w/ hand mitts to the car wash. I spray the car down with their soapy water via the hand wand. I have to do the complete cycle, because I can't stop the timer. I then quickly wash the car with the stuff I brought - one bucket & mitt for the wheels & underside and the other for the top and sides. I then pay for another cycle and rinse with regular water then the DI water.
Don't overfill the buckets or they will splash over when traveling in your trunk.
I use to do it to tho.
When I did drive the stang in the winter, I pulled it into the shop at work, (72 degrees inside) lifted it on a hoist, washed the undercarriage and washed the car in the nice warmth.
treesloth
Sep 28, 2015 07:03 AM
