The Spark Plug problem?
Old Jan 15, 2009 | 10:49 AM
  #21
stang5151's Avatar
stang5151
www.steeda.com
Has the 1 piece plugs from brisk. I'd personnally avoid the Champions. Some folks like them, some don't. Its a mixed bag depending on who you talk to.
Old Jan 15, 2009 | 11:09 AM
  #22
Blacksmoke's Avatar
Blacksmoke
The Paranoid One
Thanks. Would this be the correct one piece spark plug?
497-3VR17YS - View Image
Brisk Silver Racing Spark Plug - 3V GT - '05-'07
Recommended for up to 450 HP Applications - See Below
Old Jan 15, 2009 | 11:40 AM
  #23
cobraa99's Avatar
cobraa99
ive done a few of these for friends and done my own as well....if you have the OEM plugs changethem to Brisk or Champion. the TSB sys to torque to 25ft/lbs, i can tell you the OEM's are around 35...be sure to use Hi-Temp anti sieze only!!!...if you take your car to a dealership for them to do the change, they will cover the labor cost, if they give you a hassle, all u have to do is call the regional service to file a claim and they cover it everytime. Ford realizes it was a poor desige and will stand by the "fix" only if u dont take no for an answer. I went with Brisk and no problems so far...there is also an extractor kit available should they break off
Old Jan 15, 2009 | 11:56 AM
  #24
stang5151's Avatar
stang5151
And another note - don't buy the $200 extractor kit. There are FAR cheaper ones that do the job - ranging from $45 to $80.
The 2004-2008 F150s have had the same issue with the 4.6's and 5.4's........an extractor kit for one of those works too, and for some reason is 1/2 the cost of the ones advertised for the Mustangs.
Old Jan 15, 2009 | 12:46 PM
  #25
Blacksmoke's Avatar
Blacksmoke
The Paranoid One
Do you have to buy these one piece spark plugs online or can you get them from an auto store?
Also are those the right ones to get I posted above?
Old Jan 15, 2009 | 12:51 PM
  #26
Burnsy's Avatar
Burnsy
yes those are the correct ones. If the store does not have them im sure they can order them but you could probably get them cheaper online.
Old Jan 15, 2009 | 01:50 PM
  #27
Blacksmoke's Avatar
Blacksmoke
The Paranoid One
Ok now I am hearing that if you buy the Brisk ones you have to change them every 20k.
Is this true?
Old Jan 15, 2009 | 03:18 PM
  #28
Burnsy's Avatar
Burnsy
where did you hear that?
Old Jan 15, 2009 | 03:28 PM
  #29
Riptide's Avatar
Riptide
https://mustangforums.com/forum/5485321-post2.html
Thought I had read that around here before. He's talking about the brisk plugs there.
Old Jan 15, 2009 | 10:11 PM
  #30
doode's Avatar
doode
Champion #7978
you can find it at summit.com or rockauto.com
as for the torque wrench, i needed close to 65 ft pounds to break mine loose....no where close to the #'s the TSB stated i would need
articman
Jun 21, 2018 11:45 PM
Emblazoned
Sep 3, 2015 10:45 PM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 04:12 PM
