info:fuel press gauge
Hi guys i would like to have some info about the fuel press gauge that i will going to install ......is that very diffcult to install??? and is it possible to install a supercharger later ......when i have the gauge already??? and do you guys also know something about a pryometer?????
greettzzzzzzz from The Netherlands
To Moose's point, you need to get one of these....
http://cgi.ebay.com/ebaymotors/2005-...Q5fAccessories
Easy install, but just keep in mind that these cars hold fuel pressure for a long time after shutting down....bleed off the fuel pressure, install this adaptor, and beyond that, just follow the instructions that come with the ELECTRONIC fuel gauge. Do not get a mechancial fuel gauge.....
Yes, you can install pre-blower. It works on a stock motor just fine.....
Hi,
Thanks ! really great that you help me an for the pryometer is that also that I have to order something else?? i have order also boost/vac and do have to beware of something with that item??I have already oil press but there was also a problem told the guy how installed it for me ...he said he needed a t splitter becasue the warning sender of the dashboard was going all the time....
jwog666
12-27-2021 08:09 PM
