NORMAL OR NOT
Old Mar 23, 2009 | 06:47 PM
  #21
SikO7GT's Avatar
SikO7GT
I've done it before once too and it kinda confused me! I thought you needed the clutch in to pop it out but then i read somewhere you could actually pop the gear into neutral without the clutch so i felt better!!
  #22
kingsofcrunk's Avatar
kingsofcrunk
Originally Posted by chain1
It's normal. You can do it with any gear if your revs are right.
X2 if you match it up just right you can do it with any gear. Truckers do it all the time with semis. Hell I did it the other day to see which gears I could pull it off with. Now, if your shifter pops out of gear without you touching it, then you have a problem.
Old Mar 23, 2009 | 07:07 PM
  #23
SirKnightTG's Avatar
SirKnightTG
Originally Posted by Grinder88
I think you guys just proved that the need to push in the clutch to shift is a conspiracy from the man trying to make one leg stronger than the other so we cant walk in straight lines making it seem like we are drunk when we get pulled over allowing them to slap us with fines so they can sit in their fancy houses for one more day
LOL!!
I like that theory. It just may be true!
The Truth Is Out There. Trust No One.
  #24
shoeys08dkcandygt's Avatar
shoeys08dkcandygt
thanks again guys for clearing everything up for me. makes me feel a lot better. she has been really good since i got her. never been in the shop for anything more than an oil change. and if you saw my other post, last friday, it wont be going to the dealer for oil changes anymore.
and kings yeah hopefully that wont ever happen. lol
Old Mar 23, 2009 | 09:13 PM
  #25
gtguyonli's Avatar
gtguyonli
Totally normal, I do it all the time when I am coasting to a light, just the right RPM and speed and it pushes right out.
Old Mar 24, 2009 | 05:39 PM
  #26
Twinbo's Avatar
Twinbo
If there are any truck drivers on here they will let you know this is normal. I know they typically drive without the clutch sometimes.
The "right" revs depend on the gear you are in. The way I understand it is when the engine RPMs match up with the gear selected no clutch is needed disengage that gear.
I had a hydraulic system blow on a Saab (never again) and had to shift like this for about 20 miles until I could get it to my mechanic.
Old Mar 24, 2009 | 08:16 PM
  #27
atomicpunk's Avatar
atomicpunk
I work on and drive trucks and it's normal to be able to shift into neutral without the clutch. If you are accelerating or decrelerating with the drive line under a load it will be hard to do and bad.
Truck transmissions do not have synchronizers like our manual Mustangs. You have to match the engine RPM's to the driveshaft RPM's to get gears, takes a little while to learn. Thats why truck transmissions are called "crash boxes".
I found that the more miles on the truck transmission the easier it is to shift without the clutch- like over 250,000 miles, they get loose as they wear.
Our work pickup trucks used to be all Ford F-Series stick shifts and we had an old one with over 300,000 miles that we beat on. I shifted it without the clutch, it could be done but you couldn't rush and it wasn't smooth, but no grind.
FivePointToTheOh
Mar 9, 2020 10:26 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
breaking
Oct 2, 2015 01:27 PM
guitarman376
Sep 30, 2015 05:54 PM
96stang3.8
Sep 10, 2015 06:42 AM
