MGW shifter clearance problem
Try a hardware store for the angle finder/inclinometer
http://cgi.ebay.com/ANGLE-LEVEL-FINDER-TOOL-FOR-SATELLITE-DISH-INCLINOMETER_W0QQitemZ130266512914QQcmdZViewItemQQ ptZLH_DefaultDomain_0?hash=item130266512914&_trksi d=p3286.c0.m14&_trkparms=72%3A1205|66%3A2|65%3A12| 39%3A1|240%3A1308|301%3A1|293%3A1|294%3A50
holy long link, lol
holy long link, lol
Will do, thanks guys. I think I may have located one of my problems. I just removed the plates and LCA's again and was checking the hardware. I used the stock LCA bolts on the BMR arms/plate installation. I saw that the BMR supplied LCA bolt had a bit wider of a center section than the stock bolt. They looked the same to me on saturday when I did the install but after closer examination tonight I put the BMR lower bolts on and installed the LCA's into the upper hole like Milo suggested.
Everything is back together now and I will definitely stop by harbor freight tomorrow for the angle gauge/adjust my pinion perfectly tomorrow.
I still think I may have a problem with that shifter linkage. tomorrow's project will be moving the shifter turns back out from 10 to 5. It will probably be a smoother shift at that setting anyway.
Time for some dinner.
