Will these rims work? Thoughts?
Old Apr 1, 2009 | 08:57 AM
mynameismike65's Avatar
mynameismike65
Default Will these rims work? Thoughts?
Im looking at a set of slightly used wheels/tires.....they are from a 2001 Bullitt so the offset is obviously different then the s197. There is a link to the pages that show them. The rims are 18s and the tires are 275/35/18 all around. With my stock ride height would this look dumb or would the extra inch of wheel make the fender gap less noticable? Also any input on the quality of the tires? pics of any 99-04 wheel on an 05+ would be helpful, as well as pics of your 275s.
Tires
http://www.tirerack.com/tires/tires....num=735WR8Z1SS
Rims
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
Old Apr 1, 2009 | 10:02 AM
siberian.mist's Avatar
siberian.mist
why do you want/need a 275 up front...
Old Apr 1, 2009 | 10:14 AM
Smooth_J's Avatar
Smooth_J
275 is a bit too big IMHO. You will possibly hurt your steering geometry.
Old Apr 1, 2009 | 10:44 AM
Hootna's Avatar
Hootna
I am running 275/35/18 Toyo R888s up front with no issues on 18 x 9.5s.
Thought about running them all the way around but went with 305s on the rear since I have staggered rims. I do think that it may look a little weird without dropping the car some would be a lot of room up top.
Old Apr 1, 2009 | 10:58 AM
maxpain's Avatar
maxpain
Tires
Rims
call them up,ask for fred he's the one that knows his **** there ..talking bout offset info and all that..the other ones are just phone answerers
Old Apr 1, 2009 | 02:56 PM
mynameismike65
I dont really want 275s up front, if I had my way I would have 255s in front and 295s in the rear, but thats the size that are on the rims....they are a good deal. Anyone have pics of 35 sidewalls on a stock suspension?
Old Apr 1, 2009 | 03:07 PM
UrS4's Avatar
UrS4
First, 285 fit fine up front with the proper offset.
Note that the 275/35/18 is a significantly shorter wheel diameter than stock and will affect your speedo.
Second is using a 99-04 wheel offset, 24mm.
This will look okay. Obviously it will stick out farther than the stock wheels. The fronts may be flush to slightly outward from the wheel well. Same with the rears.
If you want pics, search my name, I have several threads with pics of 24mm wheels on the S197.
Old Apr 1, 2009 | 03:09 PM
mynameismike65
Not to get o/t but where in IL are you at? You on CMC?
Old Apr 1, 2009 | 04:29 PM
Red Beast's Avatar
Red Beast
idk, i saw a picture of a dude running some older wheels on a S197 and the wheel and tires stuck out so far that it looked like ****!!! be cafefull with this. make sure u get ur research done before commiting
Old Apr 1, 2009 | 06:34 PM
UrS4's Avatar
UrS4
Lincoln Park. No, I'm on windy city stangs, nextgenmusclecars.com. I'll get on CMC.
drfister
May 3, 2018 10:38 PM
Jwoolsey08
Oct 2, 2015 08:42 AM
movielover40
Aug 27, 2015 10:13 PM
kdryan
Aug 21, 2015 04:01 PM
Mr. D
Aug 17, 2015 09:53 PM
