2 black PVC-like panels on underside of engine compartment
I was wanting to do a bit of "engine dusting" (wipe down a few parts), but needed to remove this whole front PITA panel just to get at the items. When you can barely make it under your vehicle (sans jack), it's useless because they block everything anyway. (I don't live in a particularly friendly DIY car dwelling -- which pisses me to all hell -- especially with a new car I want to explore.)
('05-'09 models may very well have these panels also, but I haven't been under one to see if so.)
I did search the forum -- and found references to them -- but not for their purpose.
- Curious, what's the purpose of the two underside, PVC-like material panels? Are they purely for underside protection from the elements while cruising the roads? (And I'm asking because none of my previous cars had them.)
Detailing the underside of the car - I'm impressed!
I'd assume the panels are there for protection and aerodynamics. If wind is getting caught up into the underside of the engine that would cause a heck of a drag.
I didn't want to let this engine slide into the grease/gunk coating phase, as has happened all too often with previously neglected cars I've owned.
Really wish I had the space to own a hydraulic lift like in pro shops. Someday.
Good assumption -- the drag factor is something I hadn't thought of. With this vehicle riding so low to the ground, makes sense. An easy/cheap way to streamline the aerodynamics.
T.Y.
T.Y.
I hear ya. Simple Green is a very good engine degreaser, and I use 303 Aerospace Protecant on all the rubber / plastic components.
inyadreems
08-21-2015 09:10 AM
