Door window up and it goes
Old Dec 22, 2009 | 03:25 PM
07 Stang's Avatar
07 Stang
Originally Posted by up_yours_7
That's the first thing I tried stops for a little but just keeps doing it could it be a fuse about to blow?
Are you experiencing any other weird electrical problems? Check for dampness in your carpet, especially the passenger's side next to the kick panel. Pull it back and see if you feel any moisture. Some Mustangs have experienced problems with leaking thus creating havoc on the electrical systems.
If that's not it, send 157db a pm.....he is the electrical guru in this forum.
Old Dec 22, 2009 | 04:14 PM
up_yours_7's Avatar
up_yours_7
No water I sealed that area off a long time ago
Old Dec 28, 2009 | 03:36 PM
157dB's Avatar
157dB
Cut & Paste Expert
The SJB does not control the windows functions.
The logic boards are on the motors themselves.
So forget about a water leak SJB problem.
If the express works from one door but not the other,
I would suspect a bad switch on the door that the
express function does not work or a broken wire
from the drivers door to the passengers side door switch.
Click link for the wiring diagram for the windows.
Old Dec 29, 2009 | 04:31 PM
up_yours_7's Avatar
up_yours_7
well my alternator was screwing up earlier but then stopped maybe that screwed something up since the diodes in it were bad
Old Dec 31, 2009 | 11:52 AM
157dB's Avatar
157dB
Cut & Paste Expert
Yep, the system does not like the AC ripple from bad diodes.
(if they shorted closed)
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
jerrytubes
Oct 23, 2015 12:11 PM
Sep 25, 2015 06:58 PM
