Should I be worried?
Well it hasn't... today i put the car into gear and felt a slight roll forward... So I went into a flat parking lot, let the clutch out, pushed it in, put into first (while sticking my head out the window) and sure enough a slight move forward. Going back in the shop on Monday
The car is going into the shop tomorrow. Do you think I should look into lemon laws? Should I contact ford on buying the car back? I looked at everything they replaced last time I was in, asides from the gears and syncros and case, everything is new.
The first time they replaced
Manuel Transmission Assembly
Reservoir
Manual Transmission Clutch Pressure Plat or Pilot Bearing
Manual Transmission Flywheel Assembly
Flywheel Asy
Slave Cylinder
Manual Transmission Cylinder Assembly (master)
Then they bleed the hydraulic clutch system
Now there is a weird vibration at 1800RPMS
Reservoir
Flywheel Asy
Slave Cylinder
ccdguy
09-19-2015 05:20 PM
