SCT gains 16 rwhp/30tq with tune only
#22
Do we have a dyno of a stock, then tuned, then tune and intake 3 valve? I'm not doubting your logic, and I had the same thought. Without numbers however, it's simply speculation.
#24
So you turn to performance shops who have nothing to gain or lose from testing something, and take it all with a grain of salt. A good example is Kenne Bell's website. This is a company who has spent tons of time to test individual products in a controlled environment with a precisely calibrated dyno, just to see if the product would show increases in conjunction with their own superchargers. They have tested all sorts of configurations of intakes and exhaust under varying conditions and circumstances, and come to some interesting conclusions. Unfortunately, as a company who sells FI, they don't do much research on bolt on performance mods, but if you look long enough, you can start to sort the hype from the real data.
Another place to look is here on the forums.. If you search a bit you can come up with the occasional example of someone who changes from one CAI to another, and only modifies the tune to account for the MAF housings. I have seen posts where people dyno before and after on cams, intake manifolds, LT headers, shorty headers, mufflers, UDPs, CMDPs, and all sorts of different combinations of those items. After a while, you start to get a feel for what is giving the power, and what isn't. All it takes is research.. I would love it if I had the time and money to start with a stock s197, baseline it, then tune it, get a new baseline, and then start swapping parts, dyno testing after each one, and then trying different combinations, all while not changing the key power factors in the tune: AF ratio and spark advance. As long as those two factors remain the same from test to test, the power gains and losses you see are a result of the product you changed, not the tune. There is a science to finding accurate results, and you have to discount anyone who is not following that science.
#25
Look at it this way, if the cold air intake was so restrictive to cost the engine that much power, they (Ford) would have opened it up to get more power. You think a simple tweak in an inlet tube or filter would be left on the table if it could give a massive power gain?
I believe that the tune accounts for most of the hp gains but the CAI on 2005-2009s is more restrictive than on other Mustangs, isn't it?
jwog666
12-27-2021 08:09 PM
