17" tires to 18"...
17" tires to 18"...
Can I do a simple swap going from 17" wheels/tires to 18"? I found a set of 18" wheels/tires from a 2009. They still have the TPMS, so I should be good, correct? Thanks!
I believe the sensor type changed from the band style to the valve style in '10 so you should be fine there.
Going from 17" to 18" wheels, just be sure your overall tire O.D. is the same. Use one of the online tire calculators that lets you compare.
Also, I recall Ford suggests changing the bumper stops if going from 17" to 18" but many folks don't bother.
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
