Ok to patch flat tire?
Old Dec 7, 2010 | 09:05 PM
Art161's Avatar
Art161
Different tire manufacturers say different things. I would go by what your manufacturer says, or what RMA (Rubber Manufacturers Association) says.
Basically, you should be okay if it is the only puncture on the tire,
does not exceed 1/4" in diameter,
the tire is dismounted from the wheel and inspected for internal damage,
and a patch AND plug are used (a combination patch and plug may be suitable if the puncture is close to a 90 degree angle to the tread).
The patch is needed to give a proper seal to the puncture, and the plug is needed to prevent water from getting into the puncture and rusting the steel belts.
Edit: Also, the puncture should not be close to the edge of the tread--too much flexing.
Old Dec 7, 2010 | 09:13 PM
ikemikestang's Avatar
ikemikestang
Appreciate the input! I think i should be fine
Old Dec 8, 2010 | 11:36 AM
157dB's Avatar
157dB
Cut & Paste Expert
Patch yes, Plug, no.
If the steel belts are damaged, the speed rating goes out the door.
If the 'nail' pushed the steel belts to the side and has not damaged
them, then a inside patch is OK as long as it is not to close to the
outside edge of the treads where the sidewall flexes.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
