kill switch
Old Dec 28, 2010 | 12:09 AM
  #21
LostBoyz's Avatar
LostBoyz
what is the reason for the switch?
Old Dec 28, 2010 | 02:16 AM
  #22
Shadow7874's Avatar
Shadow7874
anti theft normally. Im not sure how exactly you go about installing one but normally its a switch inline with the ignition system so that when off you cant crank the car.
Old Dec 28, 2010 | 02:19 PM
  #23
08blackoutstang's Avatar
08blackoutstang
Originally Posted by atomicpunk
Don't know of any write ups but I installed a kill switch on my previous car, it was a convertible and I did it so I wouldn't have to put the top up every time I went into a store.
It was a GM product, I got the wiring diagram out of a manual and figured what wire went to the starter when the key was turned. I cut the wire as it exited the steering column and extended it to the center console where I installed a hidden toggle switch in a recessed bracket.
I don't know if you can do it on our cars because of the SJB, maybe 157db will chime in and answer that electrical question?
finally someone gets what i was getting at, no fuel line, no racing aplication, just a starter kill switch, haha, what i need to know is what wire out of our steering wheel column it is.
Old Jan 1, 2012 | 08:58 PM
  #24
jwmagnusson's Avatar
jwmagnusson
Not sure but the FUEL KILL SWITCH is for reset use only?!?. Upon crash the fuel gets cut off and this button turns fuel back on.
I too want to wire a kill switch. Bought the switch kit from KILLSWITCH website on ebay, wired it into the Relay at top of Clutch arm and GUESS WHAT... car starts in both positions of the switch. WASTE OF TIME!!! Heard about the large harness along passenger side kick panel...WOULD A WIRE IN THAT HARNESS WORK FOR KILL SWITCH use. This is a kill switch to deter theft, has nothing to do with race fuel and NHRA issues. Thanks. John, PLYMOUTH, Michigan. (Newbie)
Old Jan 1, 2012 | 09:36 PM
  #25
kput's Avatar
kput
it's in the steering wheel column. Look for the write up for the Push-Button start on AmericanMuscle.com
I believe the white wire is the one it tells you to cut.
Anyways, whichever wire it tells you to cut, that's the one you put the toggle on.
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sminemann
Sep 17, 2015 09:24 AM
