Quarter window Louvers - Cleaning nightmare?
Old Jan 30, 2011 | 07:56 AM
  #31
Sleepwalker51's Avatar
Sleepwalker51
I have more trouble cleaning the inside of rearwindow than the louvered side windows.
Old Jan 30, 2011 | 08:40 AM
  #32
AzPete's Avatar
AzPete
For the inside windows, this works great.... use this with your favorite type cleaner.
http://www.gdielectronics.com/windshieldmop.html
Old Jan 30, 2011 | 09:07 PM
  #33
ray bouquet's Avatar
ray bouquet
I've got quarter window louvers on my 2011 GT. Dealer installed them before I bought the car. They said it is adhered to the glass. Mine aren't louvered. Solid, they look sort of like an air scoop. They are a plastic material and painted to match the car paint. Anyone one know how to remove these. I don't like them. I was told to use a heat gun. Any suggestions?
Old Jan 30, 2011 | 10:41 PM
  #34
Orion_240's Avatar
Orion_240
These are my louvers on my actual 2005 GT:
http://wheelskin.com/Merchant2/merch...t_Code=DG-3180
They're still using my photo! I had 2 pairs from them and they both looked great and the paint matched perfectly.
First, the windows won't get as dirty if you have louvers over them.
Second, there is a gap between each louver that is big enough for you to insert your chamois to soak up any water left after rinsing off your car. You won't need to wash in there, but if you have a thin wash mitt it would probably fit.
Third, follow the installation instructions and they will stay on. Make sure you have them lined up perfectly as if you pull them off you will need new double side tape.
To remove them warm them up a lot in the sun or with a hair dryer and slowly pull from one corner. You cannot reuse the tape.
Old Jan 31, 2011 | 07:19 AM
  #35
Qwikphaze's Avatar
Qwikphaze
you can also buy a plate that covers the inside part of the window. like this http://t0.gstatic.com/images?q=tbn:A...--dfWfR_NW58ha you can get these to match the interior color as well.
Old Feb 1, 2011 | 10:08 AM
  #36
LordRipberger's Avatar
LordRipberger
I am not sure how they are installed, but I would assume, the 3M tape goes around the edge.
So does the tape go all the way around the entire edge of the louver?
If so, is it recommended to leave a gap on the bottom half, ever so small, so that water can run out when it is raining/washing your car?
Old Feb 1, 2011 | 02:37 PM
  #37
dcarlinf1's Avatar
dcarlinf1
I have set of the DG custom 1/4 louvers on order as I type. They are supposed to come with the double-sided tape already on there and I am considering removing a small amount of the tape to create a small hole for water to drain. One in the front. One in the rear. I too am concerned about cleaning them because I am a clean freak. I might go as far as removing them once a year just for that purpose.
cr620
Oct 3, 2022 10:18 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
