Window leak issue.
Old Apr 24, 2011 | 03:29 PM
67stangr's Avatar
67stangr
Angry Window leak issue.
I have a 07 v6 coupe and it has the windshield leak issue. I work at a local dealership in the service department and can work on my own car with help. My question is, Is it hard to seal the seams and all that if i can find the leak? Has any one done this fix them selfs?
Old Apr 24, 2011 | 03:36 PM
murry's Avatar
murry
Default why windshield?
What makes you think it is the windshield?
If you *know* it is the windshield I would take it to a glass shop,mine only charges 100 bucks to reseal; and they will do a better job, taking the
ws rightout to reseal it
Old Apr 24, 2011 | 04:22 PM
Nuke's Avatar
Nuke
Review the TSB for the water leak. If that's your issue, then the TSB describes what parts are required and how to make the repair.
Water leaking in from above the SJB inside the passenger side kick-panel is indicative of the TSB related leak. Water coming thru the lower vents is NOT the TSB described leak and is simply clogged drain ports at the bottom of the firewall on the engine side.
Old Apr 24, 2011 | 05:45 PM
67stangr's Avatar
67stangr
I was told it was leaking onto my sjb on the pass. side. And sorry bout the confusion, its not the windshield its around that area.
Old Apr 24, 2011 | 07:47 PM
alkemist's Avatar
alkemist
Sounds like the water leak in TSB. Again, take a look at the TSB and it includes repair instructions. It leaks from faulty grommets. Not a lot of fun but you need to take care of it or it will cause your SJB to short out in the long run.
Old Apr 24, 2011 | 09:17 PM
murry's Avatar
murry
Default sjb leak and others
check out this thread: https://mustangforums.com/forum/2005...k-problem.html
You will learn a lot about the leak.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
jerrytubes
Oct 23, 2015 12:11 PM
Bokeo
Oct 10, 2015 08:28 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
