Ford responds to the NHTSA investigation of manual transmissions
#42
Was he supposed to be banned or something?
https://mustangforums.com/forum/5-0l...es-owners.html
What am I missing here?
I haven't dealt with him so I don't know all the details or which Mod/Adm. took care of this issue.
#43
But with my skeptical mind along side of yours, I am wondering if that 3% are all accepted and legitimate problems diagnosed by Ford dealership techs and accepted by FoMoCo?
If the 3% mean customer claims only, not actual diagnosed and accepted problems, I wonder just how many of those did indeed result into actual diagnosed and accepted problems that resulted in legitimate warranty claims of TSB fixes under the various TSB procedures in place?
Unless Ford clarifies and says the 3% figure is the sum of actual and legitimately diagnosed and accepted problems, we can only guess what the true problem percentage is.
I get lockout from a gear every now and then, but very very rarely now since I have over 20K miles on my car. The lockouts that I used to get frequently was not from skip shift. I watched my tach message board like a hawk whenever I felt a lockout. Furthermore, I eventually bought an aftermarket tune that eliminated skipshift. I still get the lockouts every now and then.
Sure, there are times I get lockout from my own fault, i.e. the synchros doing their job by not allowing me to go into gear because the RPM of the flywheel is too far different from the tranny input shaft, but the times I get a legitimate lockout problem are not from this kind of user error. I know if I am trying to upshift or downshift too far, and thus realize my mistake, but the legitimate lockouts, if you get them, you cannot ever miss them.
I never bothered to take my car in for the problem because they seemed to virtually disappear altogether once I got above 15K miles. I guess the tranny being fully broken in virtually solved the lockout issue I had.
#44
I'd need to know more technical knowledge to come up with an actual solution, but if it were my company, I'd keep working to find a solution better than the TSBs out there so far. I'd go as far as replacing the transmissions of those effected entirely. Yes, expensive, but that's how I'd run the company.
Oh and I'd also have my transmissions made somewhere other than China where nearly every manufacturing process is messed up due to massive cost cutting and terrible government regulation.
Someone else mentioned a date of August 2010 and prior being recalled but don't some of these problems extend after that date?
