Key swap?
Can anyone tell me if the key from a 2010-, that has the remote made on to it, be programmed for an '09 that the key and remote are separate? Dealer says the key can be cut but does not know about the programming.
You can buy the fob on eBay for pretty cheap usually, and can program it yourself. Just an alternative to buying from the dealer as I bet it's pricey. I can't remember the exact process for programming but it's easy. Hopefully someone who has it copied down will chime in or something.
After a quick search, this seems to be the process for the chip in the key, and programming the fob is apparently in the manual.
http://www.fordf150.net/howto/patskey.php
Check out this thread:
https://mustangforums.com/forum/2005...ry-remote.html
I know you weren't talking about the flip key exactly, but I figured it relates haha
I just got one of these for my '12 and it says it works with '09 Mustangs. So I would assume the factory 10+ will work.
That flip key was discussed towards the end of this thread.
got it, love it, search treads for "flip key" for further details.
i'm not familiar with the newer key style you like, any chance you can post a picture?
I think he means having the key fob/remote as part of the key handle. I had that and hated it because it makes the key so damn long and clunky. couldn't put it in my pocket without issues. switched to the flip key set up and am a happy camper.
ive got the flip key as well and like it a lot, just a note tho, the flip key transmitter isnt as nice as the oem transmitter, meaning that while on the oem key i could double tap the trunk button real quick to opening it, on the flip key there had to be like a 1/2 second delay between button presses for it to register, if you double tap'd it real quick like with the oem key it would register only one press and not open the trunk.
not a big deal but somewhat of a hinderance when your used to the quick double tap of the 2011 oem key
anyways heres a comparison pic
new flip key from ebay -> 2012 acura tsx key -> 2011 mustang oem key -> 07 civic key
lincolnshibuya
Dec 8, 2015 04:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
logan409
Sep 26, 2015 07:43 PM
