Shifting problem - still.
Old Jul 12, 2012 | 02:44 PM
  #41
Blacksmoke's Avatar
Blacksmoke
The Paranoid One
Originally Posted by slickman
Okay, over the past 6 months I have installed poly motor mounts and the TQ limiters. Every gear is fine with the exception of 1st to 2nd under high rpm's (over 5,000 rpm). It will grind going into 2nd grear every time. If I keep it under 5k rpm, it seems fine. This only happens with 1st to 2nd gear. All the others are fine even at 6200 rpm.
I know these 3650's are known for gear shifting issues. The car only has 21,000 miles. I'm not new to a stick, I have been using a stick for over 30 years. Could this be syncros at only 21k miles?? I heard that there was an issue with 1st to 2nd grinding and that there was a TSB, but I' not sure.
Sounds like a good chance to put in a short throw shifter and see if that gets rid of the issue if you have not already done so.
Old Jul 12, 2012 | 02:57 PM
  #42
slickman's Avatar
slickman
Yeah, my MGW came today so, the Hurst is getting pulled this weekend. I re-adjusted the CHE tq limiters and that made an improvement but not totally gone yet. I think the new MGW may be the ticket....
Old Jul 12, 2012 | 03:11 PM
  #43
RoushGT's Avatar
RoushGT
Slickman-
I have been following this thread and reading some others. My car is setup similar to yours - Hurst STS, CHE TQ Limiters, Etc. I was having the same promblem as you, especially at the track. I couldn't hit 2 gear to save my life. I thought it was just me. Now though, when the engine and transmission get hot, it was getting hard to get into any gear, including 1st at a stop light. After much reading and adjusting shifter, TQ limiters, etc., I have found that my clutch is not disengaging. With the pedal to the floor, I can rev up the engine and the car will move forward.
I am attempting to re-bleed the system, but I am worried that either my slave cylinder is going bad, my clutch is not properly spaced, or something in the clutch is going bad. It is a Centerforce DF, and it feels fine when driving, holds well under boost. It's just not disengaging when the pedal is applied. It only has about 2K on it.
I hope the MGW fixes your issue, but you may want to make sure your clutch is fully disengaging.
Anyone else have an idea what could be causing my dis-engaging issue?
Old Jul 12, 2012 | 03:38 PM
  #44
slickman's Avatar
slickman
Originally Posted by RoushGT
Slickman-
I ran a test yesterday. Took it up to 6200 RPM gradually in first gear (not loading the drive line) and then shifted fast to second, went right in with no issues. If I put a load on the drive line (rolling ay about 10 MPH) and then go WOT and shift fast to second, it will griind. This alone tells me the syncros are fine and the drive line is moving the shifter. This is why I'm installing the MGW.
Old Jul 12, 2012 | 04:12 PM
  #45
RoushGT's Avatar
RoushGT
I am interested in knowing if the MGW helps. I am not sure if I am dealing with one problem (clutch) or two problems (clutch and shifter/linkage alignment).
Old Jul 12, 2012 | 05:04 PM
  #46
moosestang's Avatar
moosestang
Improperly torqued pressure plate.
Old Jul 14, 2012 | 02:21 PM
  #47
slickman's Avatar
slickman
Well, the MGW shifter is in and I must say, it has made a noticeable improvement! The Hurst is no comparison to the MGW, hands down the MGW is MUCH better in every way. Smoother, no notchy feel and I have it set at 3 turns.
So, now I still get a gear grind in second at WOT but only half the time now. Next is the switch over to 3.2 qts Pennzoil Synchromesh.
Old Jul 14, 2012 | 02:47 PM
  #48
slickman's Avatar
slickman
Also, going to order the JHR High Volume Clutch Line too.. That should further improve the reaction time of the clutch when fast shifting.
Old Jul 20, 2012 | 11:23 PM
  #49
slickman's Avatar
slickman
Okay, the JHR high volume line is in and I change the fluid over to Pennzoil synchromesh. Also change the brake fluid over to DOT 4. Took me 3 hours to do everything. Tomorrow I change the oil and filter. Then a test drive........!
I'm loving this MGW!!
Old Jul 20, 2012 | 11:38 PM
  #50
HxCGuitars's Avatar
HxCGuitars
Glad to hear you're enjoying the MGW! Looking forward to your results.
