Shifting problem - still.
Old Aug 1, 2012 | 08:21 PM
  #61
moosestang's Avatar
moosestang
Originally Posted by slickman
I have done allot of power shifting and fast shifting from 1st - 2nd. All of the s197 mustangs have the POS plastic clutch line except the GT500 which they did right. When you see over a 50% a drop in tubing ID (in this case more like 60%), your fluid volume is going to drop drastically which in turn is going to cause a disengagement responsiveness problem at some point during shifting. This will be more noticeable with high pressure clutch setups. My clutch is rated for 600ft lbs and is stiff so, I noticed it shortly after I pulled the OEM out and installed the Excedy 600.
This problem is a known issues, not everyone experiences in the same degree but as you add higher performance clutch systems, you will start to see a drop in clutch responsiveness. I can tell you that my clutch now is smoother then it has ever been, OEM clutch or otherwise..
The spec stage 3+ is rated at 800 ft lbs, but I'm pretty sure it uses the same pressure plate as their other clutches, so it's not going to effect the hydraulic slave cylinder like a clutch with stiffer springs in the pressure plate.
Old Aug 1, 2012 | 08:33 PM
  #62
slickman's Avatar
slickman
Oh, mine is stiff for sure. I got use to it so its no big deal anymore. When I first installed it, I was like "holy crap".. But it works GREAT, love it! The clutch movement is much smoother now, better then ever with this new clutch line.
Old Aug 1, 2012 | 10:25 PM
  #63
Simon1's Avatar
Simon1
Mine isn't stiff at all!
My clutch that is.
Old Aug 2, 2012 | 05:52 AM
  #64
slickman's Avatar
slickman
Mine is stiff compared to the stocker. This is the one I have, good for 750 ft tq at the fly wheel. http://www.americanmuscle.com/exedy-...ch-0510gt.html
nboost
Sep 16, 2015 05:35 AM
Mustangmalo
Sep 6, 2015 05:22 PM
5.0 kevo
Sep 3, 2015 06:24 PM
