Whats the DEAL!? My Gt has no Bottom End Anymore!
Old Nov 22, 2012 | 07:02 AM
  #31
mighted1987's Avatar
mighted1987
I alway hear that weird sound when puting car to accesorie before starting, not sure what is it
Old Nov 23, 2012 | 09:41 AM
  #32
AJSpags's Avatar
AJSpags
I figured it out!!!! My Charge Motion Motor is shot, The valves were not opening at all, we figured this out yesterday when I had the hood open and noticed a very strange sound coming from the back side of the motor. Whenever I turned the key on the motor would produce this loud clicking/ electrical sound. After the motor was started I manually moved the valves and they stuck in the open position, I jumped in and took the car around the block and everything worked out great! Now I will probably just install the Steeda Motion Plate delete kit instead of buying a new motor.
Old Nov 23, 2012 | 08:59 PM
  #33
robs's Avatar
robs
Originally Posted by AJSpags
Hey thanks so much for that video, by far the best one out there...should be made a sticky if it's not already. Well you definitely got my confidence up! Quick question though...when you use the Lisle tool to break the porcelain do particles fall into the cylinders?
AJ
Glad you found your problem.
To answer the question.. yes. This is a huge issue. When the electrode comes out, there's an open hole into the cylinder. I used a small piece of toilet paper to plug the hole before pulling out the Lisle tool to push the porcelain down...
Old Nov 23, 2012 | 09:51 PM
  #34
99GTvert's Avatar
99GTvert
is my username.
Good you figured it out..but what does a Charge Motion Motor do?
Old Nov 24, 2012 | 12:24 PM
  #35
solaratomic's Avatar
solaratomic
Glad you got it fixed up. IIRC your tune will need to be adjusted for delete plates so you won't lose any low end torque. Good Luck
Old Nov 26, 2012 | 10:33 AM
  #36
AJSpags's Avatar
AJSpags
Just purchased a BAMA custom tune, can't wait!
Oct 26, 2015 05:01 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
Mustangmalo
Sep 6, 2015 05:22 PM
mustangchef
Sep 4, 2015 08:08 PM
