Sponsored by:
Sponsored by:
Help a brother out
Old 12-11-2012, 04:10 PM
Goldenpony
Goldenpony's Avatar
Default Help a brother out
How do I get to the front, side marker light bulbs on my '06 GT 'Vert? Do I have to remove the fender liner?
Goldenpony is offline
Old 12-11-2012, 04:16 PM
xkape
xkape's Avatar
if you are changing them out or something, the easiest way is to remove the wheel and wheel well.
xkape is offline
Old 12-11-2012, 04:40 PM
Goldenpony
Goldenpony's Avatar
I just need to replace the bulbs.
Old 12-11-2012, 04:45 PM
waykooljr
waykooljr's Avatar
You might try reaching up from under the bumper. Otherwise, turn your wheels to the left and you'll see two clips along the center front and one on the lower inside. I think there's a couple screws to remove, then start with the two centered clips, then see if you can access the light, if not remove the lower inside, that should give you the access you need.
Edit: to clarify this is for loosening the liner enough to access the light without removing.
waykooljr is offline
Old 12-11-2012, 05:08 PM
xkape
xkape's Avatar
bulb replacement, go in from underneath.
xkape is offline
Old 12-12-2012, 12:38 AM
Art161
Art161's Avatar
From the '07 Owner's Guide:
1. Make sure the headlamp control is in the OFF position and open the hood.
2. Locate the lamp assembly from underneath the vehicle and rotate the bulb socket counterclockwise and remove from lamp assembly.
3. Pull the bulb straight out from the socket.
Install the new bulb in reverse order.
Art161 is offline
Old 12-12-2012, 03:03 AM
caaraa
caaraa's Avatar
caaraa is offline
Old 12-12-2012, 04:24 AM
Goldenpony
Goldenpony's Avatar
Thanks everybody.
MusicCity615
09-27-2015 12:53 AM
Jack Weinmann
09-25-2015 03:59 PM
GimpyHSHS
09-18-2015 12:27 PM
Sminemann
09-17-2015 09:24 AM
ShaneB26154
08-28-2015 04:47 PM
Quick Reply: Help a brother out
