Sponsored by:
Sponsored by:
2012 GT factory H pipe is stuck, help!
Old 09-28-2018, 10:54 AM
infinitenexus
infinitenexus's Avatar
Default 2012 GT factory H pipe is stuck, help!
So I'm trying to install a BBK x pipe and an MBRP cat back in my driveway with my car on some jack stands. I finally managed to get the old exhaust off, although I had to cut the factory clamps off because they were solid rust. I removed the clamps holding the factory h pipe on and it won't budge (note, I am not replacing the cats, I'm installing the x pipe that goes after the cats.). I've banged on the factory h pipe with a hammer and it just won't move. Also the long middle pipes from the factory exhaust are removed but I can't pull them out from under the car. It seems I can't jack the car high enough. Does anyone have any tips for me? First time poster by the way. 2012 GT, silver with a manual transmission. I love these cars!
infinitenexus is offline
Old 09-28-2018, 11:02 AM
infinitenexus
I sprayed the seam with pb blaster as best as I could. The remnants of the clamp are kinda in the way
Old 09-28-2018, 11:04 AM
99GTvert
is my username.
99GTvert's Avatar
Do you have any penetrating oil handy, like WD40? Maybe you'll have more clearance for the middle pipes once the H is off.
edit: Well ****, try spraying more and then let it sit for a while. You could try the hammer again with more leverage somehow. Use a long screwdriver to hit against the end with the hammer.
99GTvert is offline
Old 09-28-2018, 11:24 AM
infinitenexus
PB Blaster for the win! I got the h pipe off. Now I just need to figure out how to get the factory mid pipes out from under the car. It seems my jacks don't quite go up high enough to do so, unless there's a trick I don't know about.
Old 09-28-2018, 02:19 PM
infinitenexus
Now I need new clamps from the x pipe to the cats. Can't seem to find the part number.
Old 09-28-2018, 02:55 PM
Derf00
Gentleman's Relish
Derf00's Avatar
glad you got it off, I was going to suggest heat the part of the pipe that is on top of the other pipe to expand it and break the oxidation but, not needed.
For the clamp, try the mfg of the Xpipe they should have a recommendation. If not, Napa in their Walker exhaust section should have something.
Derf00 is offline
Old 09-28-2018, 03:24 PM
infinitenexus
No one has the information pretty much anywhere, I even called American muscle and they didn't. I was able to find it in the depths of the internet, and those clamps must be made of solid gold because they're $40 each! If I knew the dimensions of them I could get a generic one from Jeg's for half that.
Old 09-28-2018, 03:31 PM
Derf00
Gentleman's Relish
Derf00's Avatar
https://www.rockauto.com/en/catalog/...ion,clamp,5816
This perhaps?
What I see on Ford Parts giant is $40 to $50ish
https://www.fordpartsgiant.com/parts...tml?PNC=5A231B
Derf00 is offline
Old 09-28-2018, 05:02 PM
infinitenexus
That's the clamp, I just don't know the diameter. The BBK x pipe is 2 3/4" so I'm assuming something like that?
Old 09-29-2018, 08:29 AM
JJHoover
JJHoover's Avatar
you can measure your pipe
JJHoover is offline
ohfiveride
09-11-2007 11:40 PM
mjcracing
01-16-2007 12:21 PM
randybobr
10-06-2006 09:54 PM
cooper
09-16-2005 08:56 PM
92hatchLX
07-18-2005 02:01 PM
Quick Reply: 2012 GT factory H pipe is stuck, help!
