Motor idled with no oil, died - help!
Old Apr 2, 2022 | 05:05 PM
ce71's Avatar
ce71
Exclamation Motor idled with no oil, died - help!
So I have a 2009 v6 and I made a rookie mistake changing oil. I accidentally cross-threaded the oil filter and when I started the car, all the oil drained and the car quit after about a minute or two. I never drove the car anywhere. When it died it seemed more like the computer killed it as shut it off pretty quietly, no clunking or anything. It wasn't able to restart after I put on a new filter and replaced the oil. The engine turns over but wont fire.
Wondering if anyone has any insights on how to tackle this and get back on the road. I spoke top a mechanic over the phone and the suggested to just replace the engine but I'm not sure if thats the best course of action. I'm not afraid to take the time and get my hands dirty but I'm pretty young and don't have a huge knowledge base for this situation. I'm speculating that its out of time and has lost compression but I guess i'm not sure where to start or if I just need a new engine.
Any help would be very much appreciated!
Cheers
Old Apr 3, 2022 | 01:34 AM
Dino Dino Bambino's Avatar
Dino Dino Bambino
Does the engine turn over easily or is there a lot of resistance? It sounds like the engine may have partially seized from the lack of oil. I suggest you pull the oil pan and see if there are tiny flakes of metal in it.
Motor died with no oil in it usually = dead motor.
Old Apr 4, 2022 | 02:36 PM
Derf00's Avatar
Derf00
Gentleman's Relish
If the motor died quietly by itself, that means the bearings most likely siezed up at least temporarily. When metal gets hot, it expands. Without the oil in the bearings to prevent metal-to-metal contact the motor would die as soon as the bearings came in contact with the crank (main and rod bearings.
That and/or the timing is now way off because the VVT solenoids lost (oil) prime so they couldn't adjust the timing properly once the motor went from closed loop to open loop upon warm up. .
Old Apr 5, 2022 | 12:57 AM
Dino Dino Bambino
His engine's the 4.0L V6 so there's no VCT system.
Old Apr 7, 2022 | 01:33 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Oops, good catch Dino Dino, I missed that
T.Richardson
Jul 16, 2013 02:23 PM
ponyboy302
Nov 1, 2009 11:08 PM
Emanpimpster
14
Dec 16, 2008 07:16 PM
Js04sILVerBullet
Sep 28, 2007 01:17 AM
DOHCMRKVIII
12
Dec 19, 2003 07:35 PM
