Axle Alignment
Old Aug 16, 2022 | 05:59 PM
tckramer's Avatar
tckramer
Default Axle Alignment
Just notices that my jounce stops don’t line up with center of bracket that it bottoms out on. Does this look normal? (Both sides are the same. Nothing is bent or broken and it tracks correctly.)
Old Aug 16, 2022 | 06:05 PM
dusman59's Avatar
dusman59
Is the other side off as well?
Old Aug 16, 2022 | 06:07 PM
tckramer's Avatar
tckramer
Yes sir.
Old Aug 16, 2022 | 07:00 PM
dusman59's Avatar
dusman59
Do you have an upper adjustable control arm(non stock)? That can change the tilt of the rear axle. Another item can be lower control arms if they are adjustable.
Old Aug 16, 2022 | 07:25 PM
tckramer's Avatar
tckramer
Aftermarket upper and lower control arms with relocation brackets. Lowers are not adjustable. Also has adjustable panhard bar.
Old Aug 16, 2022 | 10:14 PM
dusman59's Avatar
dusman59
I suspect the upper control arm maybe to short. With a stock two piece drive shaft the angle of the rear axle is fairly forgiving. With a one piece DS one must keep proper angle between transmission and differential or vibrations will happen.
Old Aug 17, 2022 | 04:57 AM
Dino Dino Bambino's Avatar
Dino Dino Bambino
You need to adjust the length of the upper control arm to correct the pinion angle back to stock.
Old Aug 18, 2022 | 07:24 AM
Larry Stark's Avatar
Larry Stark
Default It's normal
Location is correct. Looks like car is lowered. cut down bump stop or buy Ford racing pieces. You can also get bracket to offset bump stop from Vorshlag
Old Aug 18, 2022 | 07:27 AM
tckramer's Avatar
tckramer
I will look into the offset bracket. Thank you.
Jande063
Mar 1, 2015 01:43 PM
snorulz
Mar 9, 2009 04:25 PM
Rustan
Nov 8, 2007 01:37 PM
handyandy
Aug 28, 2007 07:03 PM
BCisme
13
Sep 10, 2003 08:20 PM
