351 Mustang
intake question
Old Jul 13, 2006 | 02:25 AM
cgbills's Avatar
cgbills
Default intake question
i am going to get a 351w from a guy. It is ready to drop in except the intake. My car right now is fuel injected so to use the carb intake he has on it right now i would have to do some modding to my gas delivery and such, right? one of my thoughts was to get it for cheaper without his intake and use my efi stuff. but dont you have to replace the lower maniflod? if so what is a good manifold for a 351w fuel injected?
Old Jul 13, 2006 | 02:32 AM
347Stroker Cougar's Avatar
347Stroker Cougar
Default RE: intake question
The lower intake won't bolt up so you'll need a new lower, but keep you're upper as for it will bolt up to the lower and save you $$$ and time.
Depending on what you're upper intake is will detemine what you should run for a lower.
Old Jul 13, 2006 | 02:40 AM
cgbills's Avatar
cgbills
well i have a 90 lx 5.0 with stock efi stuff. It says 5.0 HO on the upper manifold, lol. thats about all i know.
Old Jul 13, 2006 | 04:31 PM
vristang's Avatar
vristang
What 351w lower intakes will bolt up to a 5.0 HO upper?
I have looked at a couple 351w lowers and none of them had similar port patterns to the 5.0 HO upper.
What applications of 351w would work for this?
jason
cgbills
The stickied thread at the top will have some more info on your options.
Old Jul 15, 2006 | 12:04 AM
S351R13's Avatar
S351R13
No 351w lower will bolt to a stock 5.0 HO upper. If you are planning on building it for good power a depemdablility and not all out racing then you could use a Lightning upper and lower intake. If you plan on racing or going with an aggressive cam and some more mods then go with either a trcik flow or an edelbrock. I think pro products also make a nice copy of the edelbrock.
Old Jul 15, 2006 | 04:30 AM
vristang's Avatar
vristang
ORIGINAL: S351R13
I figured as much, thanks for confirming.
I have been using a Lightning lower and Comp Cams Polymer upper for several years now. I like the combo, but I have no dyno numbers.
cgbills-
Do you have any desire to get the intake to clear the stock hood?
Tivo304
Aug 28, 2023 12:19 PM
Luke9222
Oct 22, 2015 11:55 PM
Mustangmalo
Sep 6, 2015 05:22 PM
