351 Mustang
351 dooe heads
Old Sep 3, 2007 | 07:44 PM
buget94gt's Avatar
buget94gt
Default 351 dooe heads
i just built a 347 with 1970 351 heads. i was told the intake gaskets are differnt from my 1994 block and intake. i was wondering if the head gaskets were differnt also. mainly the water jackets. i just fired it and i have water leaking into the engine from somewere. i wasnt thinking and used all gaskets for my 94 block.
Old Sep 3, 2007 | 08:16 PM
my77stang's Avatar
my77stang
Default RE: 351 dooe heads
head gaskets are the same, if you used the normal intake gaskets that would explain your leak. the gaskets you need have a "doglegged" shaped water passage hole instead of a square/rectangle
Old Sep 3, 2007 | 10:08 PM
WhiteWindsor's Avatar
WhiteWindsor
You have got to get rid of that sick avatar 77. That thing is giving me nightmares.
Old Sep 3, 2007 | 10:26 PM
my77stang's Avatar
my77stang
LMFAO
Old Sep 4, 2007 | 07:48 PM
Indy's Avatar
Indy
I have a pair of D0 heads I used to run on my windsor... I agree with the others, your leak is likely at the intake water cross-over. You will need the gaskets that have the "dog-leg" or "L" shape water passage for those heads. Otherwise, verify your intake bolt torque pattern and specs.
Good Luck,
Indy
Old Sep 4, 2007 | 09:36 PM
my77stang's Avatar
my77stang
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
kevsgt
Oct 9, 2015 10:12 PM
mustangheaven
Oct 7, 2015 10:23 AM
Drastang
Sep 30, 2015 03:48 AM
