351 Mustang
351 (427) gud idea??
Old 09-11-2007, 12:34 AM
highway21
highway21's Avatar
Default 351 (427) gud idea??
k going 2 come up on some money and wanted 2 get a 351w and stroke it 2 a 427... but keep it efi.. i know im going 2 need a stand alone ecu and huge *** injectors and some other stuff 2 swap the 351... going 2 build an aod at the same time 2 handle the power it willl make (with manual vb of course).. sodoes this plan sound gud 4 a notch mustang... thanks
highway21 is offline
Old 09-11-2007, 12:40 AM
ahittz24
ahittz24's Avatar
Default RE: 351 (427) gud idea??
What kinds of power are you looking to make? You can build a 427 and have 250hp or 650 hp what are your plans as far as heads, cam, intake, internals, power adders, etc. You dont have to have a stand alone ECU you can use a A9P and dyno tune it and it will be fine.
ahittz24 is offline
Old 09-11-2007, 12:47 AM
highway21
highway21's Avatar
ORIGINAL: ahittz24
well would like 500-600 ponys.. heads maybe afr 225s.. those should flow well.. and havnt decided on cam or intake but will get ones 2 match the heads.. the heads r gud 4 3500-8000 rpms so a cam and intake 2 operate somewhere in that ball park..and maybe some nitrous but would like 2 go alll motor... but i hav a bottle already so wouldnt hurt..
Old 09-11-2007, 01:13 AM
ahittz24
ahittz24's Avatar
My current 408 build consists ofRHS 215cc alum heads with 58cc combustion chambers. these heads from the factory have an already stout valve train and are good for the 4500 to 8500 rpm range. I would highly recommend these heads if you are looking for the 5-600 range. They are actually designed and tested on 347-421ci and are capable of 650 bhp. As for the intake I believe your best option would be the edlebrock spyder efi victor jr intake and get a 90 degree elbow for a 90mm tb.
ahittz24 is offline
Old 09-11-2007, 01:17 AM
highway21
highway21's Avatar
thanks 4 the input... will look into those heads and intake.. thanks again..
Old 09-13-2007, 12:55 PM
MadMan@TheWheel
MadMan@TheWheel's Avatar
If you still want your original question answered, 427 Windsors are awesome power producers, but suffer in the long run due to the enormous stroke involved, namely piston/rod length ratio issues. You can build 500-600 with a 408 because I have done it. The options for top ends are getting better. The "Spyder" is a good option, also Reichard Racing makes killer intakes, they have some already made and can also do conversions on a carb intake (add bosses for injectors etc). Without spray or some type of power adder I think you will find you motor just a little shy of the mark with what you are expecting h/p wise though.
Here is My build:
Sportsman II Siamese Windsor Block (Notched and decked)
Scat Forged rotating assembly (balanced)
Sold the 5 axis AFR 225's and went to TFS 5 axis "R" heads (9:5:1 Compression)
F.A.S.T. management system
Now the issue is if I will Kenne Bell that bastard or huge centri huffer, that will determine the intake decision of course as well as the camshaft, but based on Kenne Bell's folks speculations with the right cam I could be looking at the vicinity of 650+rwhp @18psi.
MadMan@TheWheel is offline
Old 09-23-2007, 03:06 PM
aode08
aode08's Avatar
you shouldnt do a 427 with a stock block , its highly unreccomended
aode08 is offline
Old 09-23-2007, 04:25 PM
kweb288
kweb288's Avatar
ORIGINAL: aode06
i heard something about 418 being the largest you should stroke out a stock blocked 351w. But it also depends on who/how its built and the tune, as these make or break an engine
kweb288 is offline
Old 09-24-2007, 10:39 AM
USMCrebel
Mach I Section Moderator
USMCrebel's Avatar
.60 i believe is the largest you can stroke it, someone correct me if im wrong but that makes a 418 like kweb said.
USMCrebel is offline
Old 09-24-2007, 11:05 AM
kweb288
kweb288's Avatar
well you can stroke it more.................just the walls will be as thin as a sheet of paper and the engine will probably crack/explode when you go to start it
kweb288 is offline
Thunderball
15
11-22-2015 11:49 PM
Sixer4Life
10-12-2015 04:26 AM
ChampInSD
10-02-2015 04:55 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
marc954
09-29-2015 11:18 AM
Quick Reply: 351 (427) gud idea??
