HOW-TO: Throttle Body By-Pass
Old Nov 12, 2006 | 07:48 PM
  #31
fitbikeco's Avatar
fitbikeco
Default RE: UPDATE TO CASSANDRAS NEW MOD(no more how do i PMs)
ya dont plug them at all the cooler air will get in there
i think
Old Nov 13, 2006 | 10:35 PM
  #32
Jerseyfury2's Avatar
Jerseyfury2
i did this mod...i felt the short hose after a while of driving....thing was HOTTT....i'm thinking about heat wrapping it
Old Dec 23, 2006 | 09:39 PM
  #33
jerseystang07's Avatar
jerseystang07
Does this only work with 2005 models?
Old Dec 23, 2006 | 10:06 PM
  #34
scrming's Avatar
scrming
ORIGINAL: jerseystang07
Yes, I believe only 2005's have the engine coolant running through the TB...
Old Sep 9, 2008 | 01:26 PM
  #35
up_yours_7's Avatar
up_yours_7
what kind of piece did you guys use to connect the hoses??
Old Sep 9, 2008 | 04:16 PM
  #36
157dB's Avatar
157dB
Cut & Paste Expert
Can anyone confirm this does anything with IAT
readings before and after the mod?
Old Jan 29, 2009 | 02:51 PM
  #37
koontreeguy's Avatar
koontreeguy
Default tb tubes
yea i got an 07 and i dont have ne tubes i was pumped to f*ck with my car too lol
Old Jan 29, 2009 | 03:01 PM
  #38
basketballord's Avatar
basketballord
" I took some temperture readings before the bypass was installed. With the engine coolant running through the TB the top of the TB was approximately 165 degrees. The bottom side of the TB was close to 180 degrees. The coolant lines themselves were about 190 degrees. Now with the bypass in place the top of the TB was only 93 degrees while the bottom was 130 degrees. So the throttle body is MUCH cooler! So in theory there should be a performance gain..."
SOURCE
Old Apr 18, 2009 | 11:13 AM
  #39
duce's Avatar
duce
Hey wont coolant spill out once you pull one of the hoses off???
Old Apr 18, 2009 | 12:49 PM
  #40
157dB's Avatar
157dB
Cut & Paste Expert
Originally Posted by Jerseyfury2
now that I think about it, since winter is coming, it might be wise to leave the TB heater in for the winter...
Maybe a temp controlled valve that allows coolant to flow
thru the TB during the winter when lets say the ambient
temp is below 40 degrees and by-pass the TB when temps
are above 40 degrees. Now that would be a good TB coolant
by-pass mod I could live with. Factory function cold weather
and performance function warm weather.
I dont have an 05 but rather an 07 with no TB heating.
I hope mine dont freeze in cold weather.
Maybe Ford found out that the S197s didnt really need TB
heating in cold weather on the 4.0 V6.....
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
guitarman376
Sep 30, 2015 05:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
2poor4u2
Sep 26, 2015 11:08 AM
