Which Tune??
Old Jan 17, 2011 | 08:55 PM
  #31
X3xMONGOOSEx3X's Avatar
X3xMONGOOSEx3X
Originally Posted by MustangFirstCar
Get the CAI w/ tunes from AM. Order 87 street, 89 performance, and 93 race. Get a half tank of 87 and install the CAI and 87 tune. When you get low, get half a tank of 89 and load the 89 tune. When you are done with that tank, get half a tank of 93 and load the 93 tune. That way you can test out each tune without bias and can decide which one you want to drive to work everyday with.
Just to correct this you don't want to drive with the 89 tune when your car is still running on 87. Make sure you run through the 87 before loading the other tune. On the other hand it's fine to run 89 with the 87 octane tune. Never run a higher octane tune than what is in the tank.
Old Jan 18, 2011 | 09:33 AM
  #32
aerbourne's Avatar
aerbourne
that explained it wonderfully. thank you very much for the link
Old Jan 18, 2011 | 10:37 AM
  #33
MustangFirstCar's Avatar
MustangFirstCar
Originally Posted by X3xMONGOOSEx3X
Just to clarify this
Old Jan 18, 2011 | 11:49 AM
  #34
AMChrisRose's Avatar
AMChrisRose
Thanks for all of the great feedback, everyone! I'm glad we're doing something right!
As for octane, you definitely want to make sure that you're running a higher octane fuel or equal octane fuel in the tank to what you have loaded into the vehicle. Never vice versa.
Even at that, if you were to get bad gas, or if you simply don't have a low octane tune (and you're not somewhere you can call us to get one sent and loaded) - have no fear. When the car is just driving normally (part throttle) without being aggressive, the timing really is close enough where the car will not detonate or ping. It will detonate/ping at mid-full throttle. That's where you should be concerned.
Old Jan 18, 2011 | 03:03 PM
  #35
MustangFirstCar
Yep. I ran 87 octane on an 89 tune until I had 3/4 87 and filled up with 1/4 93. I kept it under 2500 RPM until that tank was totally burned off though.
Old Jan 18, 2011 | 08:56 PM
  #36
X3xMONGOOSEx3X
http://www.youtube.com/watch?v=V-sred9CCTk
Old Jan 18, 2011 | 09:29 PM
  #37
MustangFirstCar
Lol!
Sixx
Oct 5, 2015 07:36 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
Explosive
Oct 2, 2015 07:45 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
