push to start help please
ok so i was installing the push to start and the part where ur supposed to splice the white wire on the end like an idiot i cut it. what can i do please help. thanks
while i was splicing it i accidentally cut in half yeah and its too short to wrap together i can get it to touch pretty good but thats it. do u think if i got copper wire from a hardware store i can fix it
Do NOT splice an extension in. Solder it. Also make sure you do NOT get solid copper core wire for the extension. Stranded wire from your local Radio Shack is fine.
Since you are probably new to soldering:
http://www.teamnovak.com/tech_info/h...der/index.html
A variable power soldering iron is not necessary for light duty wire soldering. You can buy a cheapy 35w use for around $10 for a one-time use or use around the car.
i soldered it, its fine now but one other thing im pretty sure i put everything back together the right way i even double checked but the power to the bottom of the center has no power, no heat and no rear defroster what could that b a fuse? everything else works fine. thanks
