Installing my Throttle body and plenum tommrrow!
RE: Installing my Throttle body and plenum tommrrow!
Hey Guys ok I got my CAI disconnected now and all the other crap Im at the TPS Those screws are giving me a fit and i dont wanna break it off or mess the screws up Imma put a little bit of WD-40 on the back of em. Whats the easiest way of removing them right now to me seems like they are not going to budge at all ive even tapped the end of the screw driver! PLEASE HELP
I put my old throttle body into a Sear's Workmate with the TPS botl heads facing up. A little liquid wrench and full body weight on the bolt heads with a screwdriver got them out pretty easily without rounding out the heads. Good luck.
Arghhh Ok guys how did you get the two bottom bolts off the throttle body the 2 top ones came off very easy! Please respond now Im inthe middle of this please need help they are stuck and so hard to get off!
take a 5 min break, relax, its not the end of the world, =)
now make sure you have the best position and angle, point of attack is important with cars, lol. make sure you're loosening, and use the correct socket (i hope you're using socket, much easier) if you have to use leverage, get a hollow pipe and put it on the end of the socket wrench, and use it as leverage, or just tap the end of the wrench with a hammer.
OK Guys got the Plenum installed seems like in 01 they changed mid stream of the year with this hose the guy told me. And theres no way my hose is gonna fit so i gott make a trip to pep boys but this is the hose and is this a vaccum hose? So i know what to ask for[IMG][/IMG][img=http://img234.imageshack.us/img234/4324/picture5dz.th.jpg]
kawiguy827
09-01-2015 07:09 PM
