**UPDATE**Gear Ratio Change On Predator
Old 04-09-2006, 10:22 AM
JT76
Moderator
JT76's Avatar
Default RE: **UPDATE**Gear Ratio Change On Predator
anyone?
JT76 is offline
Old 04-09-2006, 01:28 PM
mself52
mself52's Avatar
i have no idea man but i do know that 4.10 is technically 4.09 make sure there is a ZERO between the decimal and the 9....as for the tune it shouldnt affect anything to do with your speedo it doesnt change rev per mile and it doesnt change gear ratio....install the tune then go in and put rev per mile to what i said above depending on your tire size make sure you dont enter it wrong 810 rev per mile is good i believe and put the gear ratio to 4.09 (4 point ZERO 9) which is 1 hunderedth less the 4.10.... if that doesnt work call the 1800 number in your predator book because i dont knwo what else to tell you
mself52 is offline
Old 04-09-2006, 10:13 PM
JT76
Moderator
JT76's Avatar
yeah man i will call them tomarrow cause , well i know it doesnt make sense but the gear ratio does work with the "predator tune" installed but not without it......guess i got a dud
JT76 is offline
Old 04-09-2006, 10:21 PM
VARifleman
VARifleman's Avatar
Default RE: Gear Ratio Change On Predator
ORIGINAL: mself52
sure try that and here is the rev per mile should be
for 245/45/17 its 809.9 revs per mile and for
275/40/17 its 810.6 rev per mile and make sure gear ratio is 4.09 and not 4.9
you'll be off farther with that approximation than leaving it at 4.1
VARifleman is offline
Old 04-09-2006, 11:16 PM
sprostang
I ♥ Acer
sprostang's Avatar
ORIGINAL: stanggang1892
How old is the tuner? I know the older tuners wouldn`t let you change the gear setting unless you installed the performance tune. The newer version will let you though. You can download the latest version to your tuner. You just need to contact diablosport and they`ll let you know exactly what to do.
sprostang is offline
Old 04-09-2006, 11:54 PM
JT76
Moderator
JT76's Avatar
thanks man yeah i got it about a month ago lol, but i got it from mustang tuning maybe its been sitting around for a while, that sounds like it tho it will only work when i have the diablo tune in, not the "factory HP tune" i will call them tomarrow............dont i need something to plug it into the computer tho?
JT76 is offline
Jb145700
08-21-2022 06:37 AM
articman
06-21-2018 11:45 PM
Dathan
10-05-2015 05:52 AM
lmurf60
09-24-2015 10:07 PM
uberstang1
09-20-2015 06:42 PM
Quick Reply: **UPDATE**Gear Ratio Change On Predator
