OBDII Codes
Old 03-11-2004, 04:32 PM
saleen338
saleen338's Avatar
Default OBDII Codes
Can someone de-code these for me
174
181
Thanks
saleen338 is offline
Old 03-11-2004, 05:20 PM
Snydaleid
Snydaleid's Avatar
Default RE: OBDII Codes
174 System Too Lean (Bank 2)
181 Fuel Temperature Sensor A Circuit Range/Performance
Snydaleid is offline
Old 03-11-2004, 08:58 PM
saleen338
saleen338's Avatar
Any idea on how to correct them? MIL eliminators?
Old 03-12-2004, 02:39 AM
mdstud
mdstud's Avatar
I looked up the same code never heard of a fuel temp sensor... but I also looked up generic eec-v codes and this came up
174 (M) Oxygen sensor was slow in switching Single, Right or Rear HO2S - Fuel control
181 (M) Fuel system was lean at part throttle Single, Right or Rear HO2S - Fuel control
it could be you have a failing 02 on the right side... get a live scanner on it and view the live 02 sensor readings and that will tell the tail.
mdstud is offline
Old 03-12-2004, 02:43 AM
mdstud
mdstud's Avatar
Also on the MIL eliminators they are only used if you have no cats, they modify the signal to the ECM these are only for the rear 02s. The rear 02s only function is to monitor catalyst efficiency if one of those is failing you would NOT be experiencing driveability problems but you would get the check engine light... I would venture to say its the front right 02 sensor is going out... The front 02 sensors control fuel managment, timing, etc.... the rears do nothing but monitor catalyst efficiency... hope this explains a little better.
mdstud is offline
Old 03-12-2004, 02:50 AM
Snydaleid
Snydaleid's Avatar
ORIGINAL: mdstud
I've never heard it called that either but that's how Ford describes that code. Just a fancy way of sayin O2 sensor I guess.
Old 03-12-2004, 05:48 AM
mabguru
mabguru's Avatar
I get system too lean bank1 and bank2 codes. Sometimes I get some fuel to air management or something, but I'm nudging it all off until I do my big head/cams/intake manifold/injector install in a few days.
mabguru is offline
Old 03-12-2004, 11:46 AM
pichinco
pichinco's Avatar
I can't find anything concerning P0181, but I found this for P0174. It's a step by step troubleshooting guide.
pichinco is offline
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: OBDII Codes
