I recently replaced my Idle Air Control valve on my 98 gt and now sometimes when i start the car my idle rpms jump up to about 1500 or 150 whatever halfway above the 1 is and just hang there and when i take the car out of gear it jumps because its idling so high. the car used to jump up to the 1 when first started but then would fall down to about halfway between the zero and one. Any ideas what could be causing this?
it stays like this even when hot, it doesnt do it always only occasionally. sometimes i can drive the car a few miles, turn it off then restart it a few minutes later and it just hangs like that.
Sometimes CAI filter oil can coat the sensors and cause issues with idle. The IAC can be cleaned, in some cases. Also check voltage at IAC should be 12-14 vdc.
