01 Bullit intake on 02 GT
will this work or is it not worth it. ive heard that swapping the stock PLASTIC intake for the 01 Bullit intake is one of the best small upgrades is this true? please help. (planning to supercharge in near future)
P.S.-mods so far are :Steeda timming adjuster,75mm BBK throttle body,K&N FIPK,BBK Full comp headrs,BBK H-Pipe, Flowmasters,80mm MAF sensor
RE: 01 Bullit intake on 02 GT
If you consider $1,600.00 a small upgrade, then yes, its a great foundation. I am in process with the conversion myself (I have an 03 GT). I found this article, it may help:
http://www.allfordmustangs.com/Detailed/580.shtml
The parts list is detailed and accurate.
The manifold (upper and lower) are only two of the 23 parts you need to buy to make the conversion. You need a new alternator and throttle body just for starters. Your $909.00 is upper and lower only **be careful** I was not quoting labor.
lol ok, ill double check my research i want this to be an easy conversion so ill buy the "plug and play" parts (so to speak), ill be doing the labor myself so thats cool i just thought that you could swap manifold for manifold(first mustang,lol) ill find myself in these sort of troublesome areas from time to time, open mouth insert foot,lol thanks for your help i now assume that this will be a time of collecting parts for final install.
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
