steeda pulleys make engine hott?
Old 05-14-2004, 09:15 PM
04mustang
04mustang's Avatar
Default steeda pulleys make engine hott?
will steeda pulleys make your engine over heat? i was just thinking about the water pump slowing down could heat up the engine . has anyone had a problem with this and is a lower temp thermostat the answer. just wondering
04mustang is offline
Old 05-14-2004, 09:38 PM
96mustanggt46
96mustanggt46's Avatar
Default RE: steeda pulleys make engine hott?
nope especially 99 and up stangs. my stang doesent get hot with mine but i have a 180 degree thermostat and if it starts to get hot i will turn the defroster on and it turns on the cooling fan but i belive yours turns on at a lower temp so i dont think you should worry about it if you get them. you will notice dim lights at realy low idle but when you hit the gas its normal.
96mustanggt46 is offline
Old 05-14-2004, 09:48 PM
VertStangGT86
VertStangGT86's Avatar
Yea, shouldn't have problems with the underdrives.
VertStangGT86 is offline
mstahoo
SVT Forums
08-19-2021 09:15 PM
drfister
05-03-2018 10:38 PM
robjh22
08-17-2015 07:35 AM
Soldier GT
08-12-2015 03:46 PM
BlackShelbyGt500
08-10-2015 11:50 AM
Quick Reply: steeda pulleys make engine hott?
