wheel stud question
Old Jul 28, 2006 | 02:41 PM
Coley2002GT's Avatar
Coley2002GT
Default wheel stud question
is there a trick to changing the rear wheel studs on my '02??? doesn't want to go past the gear on the axle???
Old Jul 30, 2006 | 09:03 PM
03greyGT's Avatar
03greyGT
Default RE: wheel stud question
the studs will come out of the flange, I got a hammer and i slightly tapped the studs out. They kinda ride up against the ABS gear on the way out, but thats ok, if your putting in longer studs, youll have to tap them in as well, cause the gear is going to make it go in at an angle, but with a little persuasion, they will go, also you may want to SLIGHTLY grind some of the knurls on the new studs dowm a little cauase you will have a hard time pulling them into the axle flange. Its also no use to try to pound them in from the back cause the ABS gear will not allow you to get centered on the back of the stud, so it will pound in at an angle...good luck
Tivo304
Aug 28, 2023 12:19 PM
Luke9222
Oct 22, 2015 11:55 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
cbird1177711
Sep 2, 2015 08:51 PM
