98 gt tranny swap options
I have a 98 gt auto and am swapping out the non-pi headed motor and aode for a pi-headed motor and a manuel. I'd like to find a used 6 speed that will bolt up to the motor with little problems to save as much as I can for building the engine. are there any other 6 speeds out there other than the ones from 03 or 04 cobras that will work?
RE: 98 gt tranny swap options
Hey sn98Gt,
Are you buying your PI engine from Ford? I am considering doing the same thing for my 97 Stang. I have 105k miles on my engine and thought about doing the PI-Head and intake swap but I've been reminded of the old saying, if you build up the top end and if the bottom end is not not as strong(worn rings in particular) you are setting yourself up for some troubles soon down the road. It makes sense I guess. I wonder how hard and expensive would it be to order a Mach1 4v engine from Ford???[sm=smiley9.gif] But I guess the 2v would be much easier and cheaper.
actually I'm probly going to get a low milage pi motor from a wrecked car either locally or through mustang parts specialties... I'm also getting my auto to manual swap kit from them... it comes with everything needed for 1,700 including the t-45. its used stuff, but hey its in good working condition, and if it breaks, I'll replace it. this things just my everday driver, so I built it to handle good and be fun to drive, nothing overpowering... I'm saving that for my 66 chevelle
Manual swaps aren't as bad as everyone makes them out to be. It requires alittle cutting of the floor board and some matching interior pieces. The toughest part of the swap is setting up the clutch pedal...I think you could get all the parts alittle cheaper, but hey, it'll be worth it regardless if you pay that much or not!!
for giddiupstang, i did the pi swap on my 98 w/ 95k, and so far its been runnin great, but i do plan to change the berrings and possible pistons and rods sometime soon, but i did the whole swap for around 900 on ebay
Stonemonk9, did your check engine light come on after the head swap or was it already on before. I live in Metro Atlanta and a check engine light is an automatic flunk for emission testing. When my plastic intake goes which I guess it's destin to, I will check out "mustang parts" up in Winder GA and see If I can work a deal with a cobra or mach1 engine...
that check engine light was on before, i hooked up a computer to it and it said my o2 sensor was bad, and i havent gotten around to replacing that. Ya it wuld be a automatic flunk but i think i have a way around it, well c.
jwog666
12-27-2021 08:09 PM
