Help re Reverse Lights
Old 08-08-2004, 02:48 PM
BluTang
BluTang's Avatar
Default Help re Reverse Lights
Hi Everyone. My 1st post here.
I currently own a 99 GT `vert w/ 5spd, which I've had for about a year. I've also owned (as my 1st car back in the early 70s, a `68 289 hardtop.)
I recently noticed that my GT doesn't have functioning back-up lights. Not sure if it was like that when I bought the car last year.
I was told that I should check the transmission to make sure that the "plug" was connected to the transmission. I did an oil change this AM, and checked for the plug (red wire?), which looked connected. bUt I honestly didn't know what to look for ... but everything seemed OK.
I put a Steeda Tri-Ax in it last year, but don't recall unplugging anything then.
Anyway, I'd appreciate any help in diagnosing this, before I take the car to a dealer, who will gouge me $$$ for a 5 minute stupid thing I overlooked.
Thanks for any assistance.
JohnM
BluTang is offline
Old 08-08-2004, 04:15 PM
SilverGTV8
SilverGTV8's Avatar
Default RE: Help re Reverse Lights
I assume you changed the bulbs.
Might be a fuse, or you are just not making the reverse switch with the gear shift lever. I would check those items first if you haven't already.
SilverGTV8 is offline
Old 08-08-2004, 08:14 PM
purple96gt
purple96gt's Avatar
i have a different problem mine stay on all the time what could it be ? i just recently did a clutch and tri-ax shifter?
purple96gt is offline
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
lincolnshibuya
12-08-2015 04:37 PM
Explosive
10-02-2015 07:45 AM
folivier
10-02-2015 05:34 AM
Quick Reply: Help re Reverse Lights
