fuel pump problems
RE: fuel pump problems
yeah the steeda high flow pump i think thats what its called anyway... it is 40% better than stock and is supposed to be able to supply enough fuel for an extra 175 hp...
i need to get the filter and tool... is there a filter that is "better" than the other? i would have it off already but all the work and sleep i dont have much time but i am off sat. and sun. night so i will do it this weekend.. thanks for the help mikev i hope the fuel filter is my problem...
ORIGINAL: Airman21
But your not pumping out an extra 175 hp. Get the O.E.M. pump if the filter doesn't cure it.
the only reason i want to upgrade is if the price for the oem one and the price for the steeda one isnt that much of a price dif. cause i have a 100 shot and headers just sitting in my house waiting for install
If you have to drop the tank, take special care in the rubber gromet on the filler next to tank union, I messed mine up when I dropped my tank, and its like 20 bucks threw ford. Everytime I took a left turn i spilled fuel everywere. But dropping the tank isn't to hard, prob need a buddy to help you out though even enmpy its still heavy and akward
i have been having the same problems with my idle. i got a 00gt. i replace the iac valve and it was alright for about a month and then it did it again. but the fuel filter does sound logical. someone suggested it was the iac motor. but i'm gonna try the filter and see what happens. good info guys.
