Throttle Body/Plenum ?
I did research did not come up with too much!
If upgrading to a 70-75 MM T/B & Plenum is a bigger/new MAF required? I have a BBK CAI do I need bigger tubing or larger rubber fitting to go around T/B?
Thanks
Thanks
RE: Throttle Body/Plenum ?
ORIGINAL: dubarado
you can leave everything as is.... nothing new is required... a new larger MAF might help in the future if you get forced induction
Thanks... been reading the how to's on here pretty helpful looks like ACCUFAB is worth it.
ORIGINAL: ripper
Ive got the accufab it was an easy install and i hear they hardly ever leak if done right. Only thing i dont like is the finish i got. If i had to do it again id get a brushed finish.
Yeah too shiny I'm getting that next after my C/A and sub frames,
Did your MPG change, could you feel the difference would you personally recommend? Or spend 435 somewhere else?
I have found BBK 75 MM for $289.00 and seen Blue Oval 75 MM for $229.00 Neither were included in test on the HOW TO'S SECTION
JDWalton
09-24-2015 08:47 PM
