Another automatic question
Old Jan 27, 2007 | 05:07 PM
Hound11's Avatar
Hound11
Default Another automatic question
Anyone with an auto have a shift kit? How is that working out for ya?Are you able to control all the shifts w/out worryingabout your transmission going out?Bc im planning on buying one later this week
Old Jan 27, 2007 | 05:47 PM
SVTBill's Avatar
SVTBill
Default RE: Another automatic question
if your car is not heavily modded then DONT mess with the shift points they're set like they are for a reason
Old Jan 27, 2007 | 06:07 PM
clix813's Avatar
clix813
I had my shift points changed right when the warranty ran out on the car. now I have 105k miles and it still strong. It really changes the car alot. Makes it feel alot stronger.
Old Jan 27, 2007 | 06:27 PM
sfi's Avatar
sfi
I've got a 02 auto, same trans. I got a SCT and hadLivernoise professionally tune the car as well a set my line pressures and shift points to the max. I also fine tuned the shift point at less then WOT. I am more than satisfied. Livernoise motorsports(Michigan) did the tune.
The only downfall is that it shifts just as hard at WOT as crusing 30 and snapping your neck/ Alittle irratating sometimes.
Old Jan 28, 2007 | 12:36 AM
silverstang1996's Avatar
silverstang1996
you can't really control your shifts in an automatic, the tranny controls the shifts when it needs to shift. but yeah i have a shift kit in mine and im not even that modded but when it shifts i can deffinetly feel the pull it gives compared to a stock tranny
Old Jan 28, 2007 | 12:39 AM
RC5522's Avatar
RC5522
Hell a shift kit is an improvment on any automatic.
If you have patience and time to install its worth it.
Add a tuner in the mix to adjust stuff and it should be pretty kick ***.
Old Jan 28, 2007 | 02:15 AM
footpedal's Avatar
footpedal
Also check Jegs, go to the Transmission valve body replacements,, do a research of compairing shift kits and valve body replacements to what your wanting to accomplish with your car's setup..
have fun!!!
mungodrums
Oct 7, 2015 04:01 AM
04stangman
Sep 17, 2015 01:45 PM
LivingInThePast
Sep 16, 2015 12:20 PM
nboost
Sep 16, 2015 05:35 AM
