Right grease?
Right grease?
Im installing some GMS UCA/LCA this weekend.
I know i need grease, I pickedup this grease:
Super Tech, Multi-Duty Complex Grease:
Base Type: lithium grease
NLGI: Grade 2
Timken OK Load: 55 minimum
Color:red
Drap point: 500 F Minimum
is this the right kind of grease to use, or do I need something else? Thanks
NLGI: Grade 2
Color:red
RE: Right grease?
Only prob you might have with Li grease is the fact that your UCAs and LCAs are near your exhaust... but with a grease that heavy, it shouldn't be a problem... only better option I can think of is ball joint lube (like the kind you shoot into the Zerk fittings in the front)
JonnyBlazeGT
08-09-2015 10:19 AM
