Pre Exhaust work Dnyo Vid
Nice little vid of the Roush on the dyno @ Coastal in Tampa. This was prior to having full length bbk headers and x pipe installed. 90% humidity 89 degrees yielded 345rwhp and 359 rwtq 6lb boost. Enjoy the s/c whine at high volumes!
http://www.zippyvideos.com/146145667988325/100_1566/
Tim
Tim
RE: Pre Exhaust work Dnyo Vid
ORIGINAL: 02 JRClassic
Tim
Tim
I'm running the Eaton M90 Roush s/c. This is similar to the stock Cobra s/c's, which is the Eaton M112. She was certainly screaming on the dyno - 135mph in 3rd gear sounds awesome.
As far as the LT installation, I had a good friend hook me up with the install. Took the better part of the weekend, but is definately worth it. Go ceramic coated as the temps being emitted through the pipes will be significantly cooler than stainless.
It is possible that it was in fourth, but if you listen to the engine, it only sounds of two shifts and then it starts to really pull. I doubt it would've been started in second gear. I would say 345 rwhp is accurate.
