2004 EXPLORER MOTOR VS MUSTANG MOTOR
RE: 2004 EXPLORER MOTOR VS MUSTANG MOTOR
Someone actually used a ford explorer in the 2v Shootout.
MM&FF
293 hp and 310 lb-ft of torque at the wheels. This was accomplished with a virtually stock Ford Explorer engine and a set of aftermarket camshafts. The Explorer aluminum block shaved off some 90 pounds from the front end
http://www.musclemustangfastfords.co...out/index.html
MM&FF
No, the engines have stupid little design differences everywhere. the heads on the trucks are different from the mustangs. More than most likely they are Windsor heads hence that is where ford truck motors are built. The motors are designed for the specific vehicle, for example, an exploder is heavy and ment to tow, there for, it is spec'd for towing and ment for lower RPM range. they change things like piston shapes, combustion chamber sizes, cam specs (duration, lift, overlap), even stupid stuff like how many bolts holds the cam cover on. In the end. they are very close, but have there differences.
