Removing the plastic bezel around the Radio
03-05-2007, 01:57 PM
How do I do this? The plastic is not very flexible.
Thanks,
Also how do I remove the door tweeters to replace them?
Thanks,
03-05-2007, 01:58 PM
EXTREME Moderation
RE: Removing the plastic bezel around the Radio
I believe both of them pull right off. but be careful, or you'll break your cheap interior.
03-05-2007, 02:05 PM
You pull the plastic piece around the shifter off first, then the piece around the radio just pops off.
03-05-2007, 02:09 PM
Quote:
ORIGINAL: korn253
+1
i had to change my fog light switch.
03-05-2007, 02:14 PM
since you have the center piece answered, to change the tweeters (as redass said) just pull off the grill around the speakers (if you'd feel more comfortable get a screwdriver, and slowly pry around where the mesh meets plastic on the tweeter housing and there's two small bolts holding the tweeters in
03-05-2007, 02:37 PM
but to get to the harness connectorfor the tweeters, the door panel will need to come off
03-05-2007, 02:41 PM
Quote:
ORIGINAL: korn253
the radio bezel on my 99 has 2 ..7mm screws under on the bezel near or underthe radio..dont forget to remove them first (if you have them)..
jwog666
12-27-2021 08:09 PM
kevsgt
10-09-2015 10:12 PM
Dathan
10-05-2015 05:52 AM
breaking
10-02-2015 01:27 PM
mrappe
09-26-2015 10:16 AM
2003 ,
2006 ,
95 ,
96 ,
99 ,
bezel ,
center ,
ford ,
mustang ,
plastic ,
radio ,
remove ,
removing ,
sterio ,
tweeter
