Intake silencer????
RE: Intake silencer????
ORIGINAL: 6mustang6
K&N says you gain 10 hp on a stock motor. I say this is bull****. I doubt you get 5 hp. I installed one and didn't feel a difference, It felt like i lost power actually.
For the OG poster... removing the silencer is in effect a cheap CAI... it will not harm your motor any, and will not add a huge difference in performance.... but then nothing aside from a blower or turbo will add a huge difference in performance in these cars... everything other than a power adder is just a little something to give you a bit more of an edge over stock!
ORIGINAL: langod
Ummm... more like 3. I know, I dyno'd it. 226rwhp stock, 229 with silencer removed and K&N FIPK installed.
ORIGINAL: MoKo_04GT
silencer removed with a k &n filter is dyno proven 9hp...there is a sticky on it, in tech articles and how to's.
I noticed with the silencer removed I have a little more top end pull, however I seem to have a very slight mid-range sag when the weather is hot outside and I've driven the car on a long trip.
I put back the silencer to test and sure enough the sag is gone.
Not sure what to make of it.
ORIGINAL: MoKo_04GT
here ya go....read the article....if you add a k&n its about 9hp just as i said.
remove the silencer (4 -5 hp).....add a k& n (3-5 hp)....equals about 9hp = pretty much a cai
http://www.musclemustangfastfords.co...5mmff_boltons/
a CAI will net you 1 hp, someone on yellow mustang registry dynoed a MAC CAI and MAC cat back and got a total of 4 horses
removing the silencer wont do anything more then a CAI, which is nothing, however, it can cause some terbulance in the MAF and cause gas milage to go down, happend to me
ORIGINAL: MoKo_04GT
rofl you guys are nuts!! heads...cams...full exhaust, then upgrade the filter.....for 9hp?!?!? dude....put the pipe down.
ORIGINAL: sstang
+1. 3 hp is more like it. You couldnt get 9 hp unless you did like heads+cam+full exhaust and then upgrade the air filter!
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
