downshifting????
RE: downshifting????
ORIGINAL: 2000Si
... and clutch, and motor, valvetrain, drivetrain, everything.
ORIGINAL: mdvaldosta
Its hard on the sycro's when you downshift hard
ORIGINAL: yellowstang98
equalling hard on the all mighty WALLET
ORIGINAL: 2000Si
that it is
Guest
Posts: n/a
ORIGINAL: stonemonk9
I use the motor to downshift all the time. It wont hurt anything really like Silver says aslong as u match the engine rpms with the speed ur goin and the gear.
downshifting at a higher rpm, using my car as an example (yes it's not a mustang, but i can't use something I don't have...)
Let's say if I was sitting at 60 in 5th gear (around 3000 rpm) and dropped it to third (5500 rpm - vtec engagement), doing that constantly would start to put excessive wear and tear on the valvetrain, the springs would start to get soft and the retainers would get hard and brittle, all this will cause the valves to eventually start floating.
valve float= bad, especially on an interference engine.
At moderate to slow speeds, downshifting is preferred just before you touch the brakes. I have been doing it for 45 years without hurting any engine or transmission. Yes, I have an 03 Mach1 so I know what you guys are talking about.
Key word moderate......self control....how fast do you want to come out of the turn or stop should determine it.....I coast a lot to lights that I know I have to sit at.....why bring the RPMs up to get to the light? When going around a turn and want to perform match the RPMs down a bit to accelerate out and hit the Apex!
Go speed racer go....
.......if you're braking slowly and let the rpms fall almost to idle before down shifting, i think you will be fine. I have been doing that in every car i have owned for 20 years and never had a problem.
