is tis a good tuner?
for you guys that know about these things is this a good tuner and is it worth the 350?
http://www.machperformanceparts.com/...ml?id=aFzDnpHY
RE: is tis a good tuner?
If your gonna get a tuner it should be the new SCT one that you can get emailed new tunes and download it to your tuner. www.modulardepot.com
The Diablo Tuner is I think better than the SCT. The tunner can get its downloads via e-mails just like the SCT. The Diablo Preditor Is the first tunner to come to the market everyone else followed suit. I can give you all the detail. Just Call me Dave
1-888-434-1099
1-888-434-1099
The only flash tuner with exclusive FlashForwardTM ability allowing you to download custom tunes via Internet from a nationwide network of ChipMaster Revolution tuners (locate your nearest dealer in our Dealer Locator).
The only flash tuner allowing you to get revision updates via Internet.
The only flash tuner with exclusive FlexAdjustTM technology which allows you to vary the engine and transmission parameters over a wide range.
The only flash tuner with advanced OBD-II scanner capability:
read fault codes (DTCs) and their description in plain English (no need for extra books!)
both standard and proprietary fault code text included
reset fault codes
live data monitoring
The only flash tuner that logs* live data. Play back log on Predator or PC (Log Viewer for Windows is available FREE on our Downloads Page).
The flash tuner with a true graphical display that's 300% larger then the competition's puny text only display
The flash tuner running on a custom high performance, multi-threading KROS operating system
5) Dyno Tested Performance Tunes
The Predator was created with one thing in mind, POWER! Average power gains are in the 15-20 RWHP range. The Predators additional power makes itself noticeable immediately with an increase in power that starts in the low RPMs and builds into a frenzy at the high RPMs. A Predator equipped vehicle will notice significant improvements in drivability. The additional power and improved shift patterns created by the Predator tune will yield quicker acceleration and better mileage, whether it is in town or out on the highway. The power increase in the lower RPMs will yield a better throttle response. The increase in MPG is a byproduct of maximized engine efficiency, the improved timing curve and air/fuel ratio creates a more complete combustion, i.e. the engine extracts more power from each molecule of gasoline. DiabloSport has generated all dyno tested tunes.
Predator tunes re-map the:
Fuel Curves
Timing Curves
Extend Speed Limiters
Extend Rev Limiters
DiabloSport Performance tunes require the use of Super Unleaded / Premium grade or 91 octane fuel only, like carried by Amoco/BP, Sunoco or Mobil.
6) Adjustable Parameters
The Predator features end user adjustable parameters so the end user can customize his/her tune depending on other modifications done to the vehicle. Because we allow for timing and fuel adjustments the end user can optimize the tune for his/hers specific vehicle utilizing a dyno with proper air fuel monitoring and utilizing the Predators live data feature to monitor timing and other vital parameters.
The Mustang Predator allows the end user to adjust the following parameters:
Dual timing adjustment points (2000-4000 RPM / 4000-7000 RPM)
Timing table (+10% / -40%)
Dual fuel adjustment points (2000-4000 RPM / 4000-7000 RPM)
Fuel table (+40% / -15%)
Idle (+/- 20%)
On/Off switch for Traction Control
Raise Speed Limiter
Rev Limiter
Re-Calibrate Speedometer for Gear and Tire Size Changes
WOT Shift Pressure
Part throttle shift firmness
RPM Shift Points
Torque Modulation (for better shift feel)
Cooling Fan ON/OFF Temperatures
Rear Oxygen sensor disable (use for off-road vehicles only)
Disable EGR (use for off-road vehicles only)
All of these parameters can be adjusted on the DiabloSport tune and/or the factory tune
7) Diagnostics and Live Data Logging
The diagnostic feature allows the end user to scan and erase fault codes as well as monitor live data while driving. Predator can read and erase fault codes, and contains all the Ford specific P codes. Predator diagnostics will work on all 1996-2003 OBDII Ford Mustangs or F-Series Gas vehicles. The diagnostics features can be used on any Ford OBDII vehicle, regardless if the tool has locked itself to a specific vehicle or not. Data logging is available as well. Logging stores 30 minutes of data, with slow rate the logging allows for up to 90 minutes. The log can be viewed in Predator, or it can be uploaded to PC for viewing with the FREE DiabloSport DAT Viewer for Windows software (download yours now).
8) PC Interface Kit
PC Interface Kit allows you to connect your Predator to your PC. More information about why would you want to do that is here.
9) Custom Tuning
We can do custom tunes for almost any application without the need for end user to send us the Predator. We have PC interface software available for download and the tunes can be sent via e-mails. Please visit our Custom Tuning Page for more info.
reset fault codes
Fuel Curves
Timing Curves
Extend Rev Limiters
Idle (+/- 20%)
Raise Speed Limiter
Rev Limiter
WOT Shift Pressure
RPM Shift Points
8) PC Interface Kit
9) Custom Tuning
Luke9222
10-22-2015 11:55 PM
09-01-2015 08:16 PM
