Engine install
RE: Engine install
What kind of long tubes? If they are mac you cant drop it in with the driverside header on if its BBK you can you just have to wiggle the engine around and have a good angle. I put mine in with the passengerside Mac longlube on but had to put the driverside on after.
RE: Engine install
Disconnect the obvious like throttle cable ect.
Disconnect the two main harness connectors.
Take loose the wires that go from the engine to the power distribution box.
Take the power steering pump reservor off and disconnect the large line on the bottom.
RE: Engine install
Lift the car drain the oil and tranny fluid and disconnect the steering shaft.
Take the dust cover off the clutch lever (if it's a manual) and take the clutch cable loose.
Take the line off the bottom of the power steering pump.
Disconnect the two power steering cooler lines.
RE: Engine install
Take the wheels, brakes and rotors off. Take the springs out and disconnect the lower a-arms and steering joints from the spindle.
Drain the freon and disconnect the AC lines. Disconnect the heater hoses also.
Take the midpipe, driveshaft and cross member out.
Put the motor and tranny on jack stands and lift the car off the engine slowly.
RE: Engine install
i put in my engine and tranny at the same time didnt need to disconnect the ac lines just take off the compressor. with mac lts you must disconnect the steering shaft and feed it through the header you caninstall the engine with both sides on.
Design1795
01-24-2017 10:38 PM
NorthAmericanTuning
03-18-2016 11:21 AM
Design1795
08-24-2015 04:41 PM
